400ex carb
Old Jul 2, 2000 | 08:19 AM
dave400ex's Avatar
i have a 99 400ex with a 440 stroker kit in it. it has been jetted and i run a k&n air filter. I recently just purchased this quad and i love it. I am also not very familiar with it so bare with me. My question is this. The other day after doing some riding, i noticed that my overflow on the carb was dripping at a steady pace, so i turned the gas **** to the off position. Later after i got home, my truck bed had gas in the bed and the overflow was dripping again. is this normal? i thought that the overflow would only drip after excessive choking, or if the machine was tipped up. Am i correct or should i just allways just trun the gas off? This seems very odd to me. Any one with some tips would be appreciated !! thanks
Old Jul 2, 2000 | 02:35 PM
Skunky's Avatar
That does not sound normal to me... i wuld take the carb off the bike and give it a good cleaning. The little plastic in your float bowl mike be corroded..
Old Jul 2, 2000 | 02:50 PM
tprender's Avatar
What has happen is that the float is working up and down as you are driving with the quad in the back and the gas has to go some place. It is going out the overflow tubes. You will also get this when you ride a wheelie and see gas coming out the overflow tubes. If gas come out with the quad just sitting on the ground, the float is sticking. I think that the 400 float is plastic and can not be ajusted. But, you might have a piece of dirtin the needle valve.
Old Jul 2, 2000 | 03:22 PM
Skunky's Avatar
ya the float is plastic and it can be replaced
Old Jul 2, 2000 | 06:45 PM
zootue's Avatar
skunky email me at zootue@earthlink.net
You need to come out to the mx track in Vegas. The quad class needs more racers.
Later Ron Zootue Racing #14
Old Jul 5, 2000 | 12:39 AM
brandon250r's Avatar
try tightening the over flow screw on the side of the carb.
Reactant
Mar 30, 2022 02:08 AM
GregM
Jul 29, 2015 09:41 PM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
