Toe-in on 450 ES
Old Feb 4, 2004 | 10:36 AM
Slowleaks's Avatar
Default Toe-in on 450 ES
Hi everbody, I'm having trouble understanding why the toe-in on my 2003 foreman es is supposed to be set approx at 1 9/16 toe out, I've never heard of toe out, has anyone, and can you explain why? My machine does steer harder at factory specs, when I change it to approx 1 to 1 1/4 toe-in, It steers like a dream. But I thought maybe this has something to do with the front differintial operation. Anyway would like some thoughts or logic to this. Thanks Slowleaks
Old Feb 5, 2004 | 11:46 PM
cluby's Avatar
Yeah I know Honda and Bomb (ski-doo) are the only ones that run there quads with toe out. They say that they track better on side hilling with toe out you can run it which ever way you want yo set it
Old Feb 6, 2004 | 12:50 PM
Coyotechaser's Avatar
If you look at my first picture, you can see another example of toe out. I think it looks a little excessive. I haven't measured mine yet but I do plan to bring it in a little. I have no idea why they do this. It's like I'm trying to go in two different directions at one time.
Old Feb 6, 2004 | 01:10 PM
hondabuster's Avatar
the spec in the manual is 1 3/8" plus or minus 9/16", toe out.
Old Feb 6, 2004 | 01:47 PM
So does that mean that it can be set anywhere between 13/16" to 1 & 15/16" toe out? Mine must be set at the full 1 & 15/16".
Old Feb 6, 2004 | 05:04 PM
Yes, your math is right.
wheel alinement
Old Feb 7, 2004 | 10:44 AM
Slowleaks's Avatar
Thanks Guys, I'm going to leave mine set with Toe-in for now because it sure steers easier. But I am going to check to see how many threads I have got inserted into the tie rod itself to make sure it won't be able to pull out. Again, thanks for the input. Slowleaks
Old Feb 7, 2004 | 10:46 AM
Chilly's Avatar
Mine was toed out when I got it, I read the Clymer manual which says it should be toed in, so I set it to 16 mm toed in.
Toe-in
acrosstheveil
Sport Quads
May 29, 2014 03:11 PM
acrosstheveil
May 28, 2014 01:53 PM
sms0000
Sep 19, 2008 09:39 PM
RAMTechRC
Nov 18, 2005 02:51 PM
TRIPLELSTROKER
Jul 6, 2005 06:02 PM
