FOREMAN 450S IDLE PROBLEM
Old Feb 11, 2004 | 12:46 AM
themacdadt's Avatar
Default FOREMAN 450S IDLE PROBLEM
whitish tan looking
Old Feb 11, 2004 | 08:37 AM
dzzy's Avatar
Hmm...that you have to hold the throttle open to restart it would indicate a rich mixture. You can find out for sure by opening the choke cable slightly when it's starting to die, if it makes it worse, it's rich for sure. It could be just an adjustment problem, such as idle speed or mixture screw or a combination of both. You need to follow the Honda procedure for setting them. If you don't know the history of the machine, somebody could have drilled out the slow jet in a ham handed attempt to clean it. Also check carefully the slow jet air bleed holes on the jet, and the air bleed circuitry in the body of the carb. I think it gets its supply of air underneath the carb slide diaphragm, and also goes through an air cut valve, then down to the slow jet itself. You may want to test the air cut valve itself, in conditions of high intake manifold vacuum, that is when you close the throttle at high speeds, it cuts air to the slow circuit, to avoid decel popping and backfiring. If this device were stuck closed, ( can't say I've seen one fail yet) it would run rich. You may also want to try a new spark plug, in case yours is on the verge of fouling.
Old Feb 11, 2004 | 04:54 PM
hondabuster's Avatar
I think you just have a misadjusted carb,
carb cleaning
Reading this may help you.
Old Feb 11, 2004 | 09:00 PM
cluby's Avatar
have you ever done anything with the air filter.
or did you have it standing up on the rear rack washing it or something like that
try removing the air filter and see how it runs and starts sounds like you might want to wash it out and reoil just don't use motor oil either some gear oil or get the honda air filter oil
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
