TRX450 Valve adjustment issues
Old Feb 23, 2004 | 10:19 PM
  #21
MIA416EX's Avatar
Default TRX450 Valve adjustment issues
Originally posted by: KGB
OK everybody. There are shim under buckets on the intake side, just like a Z400 engine, the ex. side has shims, but no buckets. The only lock nut style adjustment , is for the decompressor. You use a shim to adjust it. The have thickness on them, you use a thicker or thinner, depending on the reading.
It is extreme over killt o adjust shim style valves more than every 100hrs.
I did it before I put int he cam, after I put inthe cam, after first ride with cam. Its good to go for a while.
KGB
did you have to adjust anything, or did you just inspect each time...?
Old Feb 23, 2004 | 10:28 PM
  #22
maytag's Avatar
i never adjusted mine when i put my cam in,seems fine i have hrc kit with curtis sparks pipe.it runs perfect ,honda tells me check valves in six months
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Unzzy66
Jul 11, 2015 10:01 PM
Mojave250A
Jul 11, 2015 10:38 AM
MNatv89
Jul 7, 2015 11:36 AM
