400ex Highest Compression Pump gas?
Old Feb 16, 2004 | 05:53 PM
Sandrider503's Avatar
Default 400ex Highest Compression Pump gas?
Call WhiteBrothers racing they can help you. Although they can be a$$ holes sometimes. They know there stuff.
Old Feb 17, 2004 | 03:30 PM
cals400ex's Avatar
why you just jumping to a 440? i personally would get a 416 with a nice cam if you dont' want to spend too much cash. a 416 with a cam will out run a 440 any day of the week if it just has a piston in it. the 440's produce a lot of heat too.
Old Feb 18, 2004 | 12:08 AM
BSA's Avatar
BSA
The traditional rule of thumb is to divide the available octane by 10. As you go above that ratio you have increasing issues with detonation, heat, starting, .. These issues are addressed with swirl patterns on the piston crown and/or head, ignition profiles, etc. etc. Whatever piston you get, make sure you ask what octane that particular design needs. It will vary by compression ratio and piston crown shape.
Back when Sunoco used to advertise that their lowest grade of gas was 100 octane, milling heads and high compressions were an easy way to get HP. Today's regular at 87 octane is equivalent to the old Gulftane. The only engine that would run on Gulftane were the old 6volt VW bugs with 7:1 compression ratio engines. I thought it was great when I found Gulftane for my old bug because I saved a whopping 2 cents a gallon compared to regular which was a horrible 19 cents a gallon.
Old Feb 18, 2004 | 03:18 AM
TNTQuadJunkies's Avatar
I was told when doing my Big Bore ( I have a 426) that no race fuel is needed for this comp in mine and will actually run a bit better w/o. Unless your changing the timing curve then you may detonate (like we done to the Predator with a Vortex CDI we have ro run 60/40 C12)race gas isnt needed. I have heard no pinging with mine and runs like a champ. These reccomendations came from 3 major Racing Companies. Tina
Old Feb 18, 2004 | 03:19 AM
  #15
Originally posted by: YouSuk678
I wanted to stick with just pump gas because i dont have the time or money to be running around getting race fuel. But does JE offer a 440 kit or is it only the 415cc i saw on some website. IF someone could give me a link to the JE site and if they offer a 440 kit it would help a lot.
thanks
Call Rich at Hetricksracing. He is a whiz when it comes to the Ex........[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 19, 2004 | 10:16 PM
  #16
maddog56's Avatar
Originally posted by: Sandrider503
Stay away from the Weisco piston. They are not a true compression, run a JE piston they are the closest you can get.
Actually wiseco are much closer to advertised. JE pistons usually actually run high.
Old Feb 19, 2004 | 10:34 PM
  #17
Isnt JE and Ross about the same? I thought I read that somewhere......
Old Feb 19, 2004 | 11:56 PM
  #18
maddog56's Avatar
no, the ross pistons are closer to the actual compression as well. a 12:1 je is actually about a 13.3:1. 11:1 is about a 12.4 or something.
Craycraft just switched to ross pistons in their 686 raptor big bore kits. They say they are much stronger.
Old Feb 20, 2004 | 12:01 AM
  #19
So Far Im happy with my Ross piston.....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 20, 2004 | 06:48 AM
  #20
Yamaha660R's Avatar
I am the first 686 with the Ross Piston. I'm sending my parts to Bob Monday. So I will be the first 686 Craycraft this is based around the Ross Piston. Yay for me!!!
