rev box for 400ex
Old Feb 22, 2004 | 06:09 PM
673RaptorKid's Avatar
Default rev box for 400ex
would the rev box help much when the 400ex only has a white bros full exhaust system and k&n filter and degree key? Would it be worth the money? Also what companys should i get white bros. or big gun? I have herd that after buying the box starting becomes an issue. Is this ture.
Old Feb 22, 2004 | 08:42 PM
cals400ex's Avatar
it won't help for power. i didn't notice anything until i built my motor where the extra rpms are beneficial. i wouldn't get the big gun or white bros if it was me. i have heard good things about the gt thunder and tc boxes. many of the other ones will give you starting issues.
Old Feb 22, 2004 | 08:55 PM
Yamaha660R's Avatar
It will give you more rpm's, which helps it some. Alba sells one for $59.99. Not bad for a mod that takes 2 minutes to install. Also make sure battery is fully charged.
Old Feb 23, 2004 | 06:56 AM
pungohboy's Avatar
I have a WB Box and I really dont notice the differance. I kept my stock box and i am now using it since it is cold out. The Revbox Does have trouble starting when it is cold (below 40) outside. I have heard of people keeping the stock box mounted and mounting the revbox somewhere close to it so they can warm it up with the stock. I have a WB E series slip on, K&N filter with outerware and it is jetted and i really cant tell the differance with the WB.
Old Feb 23, 2004 | 12:31 PM
greencon's Avatar
Save your money. On a mostly stock 400 the power drops off dramatically in the higher revs.
Old Feb 23, 2004 | 01:25 PM
dunefool's Avatar
Don't buy the White bros rev box, trust me. Consider an Electrix box, which has no rev limiter. I have one and it works perfect. No starting problems.
Old Feb 23, 2004 | 05:37 PM
Dfitz's Avatar
Hey Rkid do you think that degree key makes any difference on the 400ex?
Old Feb 23, 2004 | 05:38 PM
Dfitz's Avatar
dunefool where did you get your electrix box?
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
