What's stopping Honda from doing true 4WD?
Old Mar 11, 2004 | 04:30 PM
  #31
hondabuster's Avatar
Default What's stopping Honda from doing true 4WD?
bamaboy, Youll have 4 wheel drive coming down a hill? Engine braking in front? How about around a corner....4 wd drive then? Each system has its weak spot. Everything has its trade off, its not only honda that compromises.
Old Mar 11, 2004 | 05:34 PM
  #32
hellbilly's Avatar
100% correct
Old Mar 11, 2004 | 06:06 PM
  #33
TellicoGrizz660's Avatar
Actually he will have 4wd going around a corner!!! As far as your Honda having 4x4? LOL!!!!!!!!! Thats a Joke! I on the other hand have the option of having the 4x4 system such as yourself, and 4x4 that you DON'T have! WE ALL KNOW very well have "good", LOL, the 4x4 system is on the Hondas!! You can LITERALLY hold the tire from turning and watch the other one spin!
Old Mar 11, 2004 | 09:59 PM
  #34
honda450es4x4's Avatar
TellicoGrizz660
U r a stupid **** at least mine starts
Old Mar 11, 2004 | 10:16 PM
  #35
Originally posted by: honda450es4x4
TellicoGrizz660
I'm sorry your little 3x4 doesnt live up to my Yamaha!!! Mine starts very well! Leave the name calling out of it little boy!
Old Mar 11, 2004 | 10:23 PM
  #36
in what a heated garage?
Old Mar 11, 2004 | 10:33 PM
  #37
hellbilly's Avatar
Wow your right Honda does suck, ill sell my Honda tomorrow and go buy a … no wait I have to drill holes in that one to keep it from overheating, maybe ill get a … no wait that one has plastic racks that I cant hall anything heavy on… I KNOW ill get a … naaa that quad is in the shop more than it’s on the trail… no thanks ill just stick with my sucky Honda that has gone everywhere I need it to go and some places I would never go [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 11, 2004 | 10:52 PM
  #38
RINCON's Avatar
No he won't, I'm sorry but the only way a Polaris has 4WD is when the rear wheels rotate 1/4 turn faster than the fronts. So you can leave it in 4WD all you want, but unless you spin the rear tires it won't engage the front ones. Not saying this is a bad thing, just the way it is.
Also the ranchers should have the newer tourque sensing front diff. The brake tap thing also works some of the times, but usually the front brakes on a honda that is anything but new are worn out.
Polaris' 4WD system is also no good for rock climbing. But in the mud it can't be beat!
Old Mar 11, 2004 | 11:19 PM
  #39
Yellow650Rincon's Avatar
Originally posted by: Andy Bassham
I'd like to see a forum where this "My limited slip spins all 4 tires at all times" thing HASN'T been addressed too many times. Bull, I don't buy into any special differential on any machine when it says limited slip.
Bottom line, if you have one and are truly confident in you limited slip, then try this test. Warning, you might come away dissapointed and buy a Grizzly, Prairie, AC650, or even a Polaris god forbid.
Jack your machine up. All four tires front and rear off the ground. Make sure its sturdy, and will not fall off or have a tire catch the ground. OK, put it in gear and make sure its in 4wd if it even has that option (Rubicon owners need not apply). Reach up there and grab one of your front tires and hold it in place, and then give it some gas. You should feel a quick hitch, and then you should be able to hold that tire at a standstill while your other front tire spins freely. If you can't hold that front tire, and both will spin evenly, then I'll shut the hell up and admit you have a good limited slip system.
Try it. I did on my AC500 and thought about puking, then I thought about buying a Polaris. Then I just said the hell with it and waited 3 years for somebody other than Polaris to put a decent differential in a quad.
Honda needs to quit playing that simpicity crap and put that stuff on their quads. The Rubicon is freakin awesome in my opinion. Better than the Rincon overall. (Rincon would be better if they would have stuck with the Rubi transmission). Slap disc brakes on those things, add a differential lock and 2wd/4wd select feature to all your 4x4's, and with Honda's reputation, they won't just get the dyed in the wool honda fans. They will get sales from all those fence straddlers too that don't care about brand.
I have tried this test before. At idle when my tires are spinning I can stop the one with my hands. As soon as you touch the throttle and get them spinning it rips right out of my hands and you CAN'T hold onto that tire anymore. Would you call that "good limited-slip"?
Really, you guys need to friggin grow up! Go out and ride or something! You sound like a bunch of kids arguing here on the internet!
Old Mar 11, 2004 | 11:45 PM
  #40
twistedoak66's Avatar
i used to own a 96 300 4x4 i do a considerable amount of mudding driving through the heaviest nastiest brush you can imagine logs, bog ,trees, you name it i did notice that it had a limitied slip front end but it seemed to pull with all four most of the time even on hills and in weird articulation but on the odd occasion it didnt it never really just sat there both front tires always seemed to be working in some fashion but one might on an odd occasion lurch and spin real irradic but it did pull not as hard as the other tires but it always seemed to imprees me that it seemed to be using all four pretty much all the time i just purchased a new rubi i havent had that in the bog yet but i can only hope it pulls as hard as the old if it does i wont have any worries but lockers would be nice then you know your getting full power out of both
