400ex
Old Jul 12, 2000 | 01:06 PM
wideopen's Avatar
I just installed a k&n air filter with the k&n jet kit #170 main no air box lid.she runs like a stripped but monkey in the open but feels a little sluggish on tight trails im also running a wb e series slip on with 12 discs.any suggestions on making low rpm a little more snappy without losing top end power.
thanks
RIDE LONG
RIDE HARD
W.F.O.
Old Jul 12, 2000 | 01:39 PM
Skunky's Avatar
Did you turn out your air/mixture screw 3 1/2 turns? I think you are running too big af a main jet.. I live in vegas and run a 165 due to the heat here.. in the winter i will go to a 170 but with what you have i think you should be running a 160,165,,, you are going to have to play with it...
Old Jul 12, 2000 | 04:04 PM
ccarpe1's Avatar
I had to raise my Dyno-Jet needle to the third notch and open up the air mixture screw 3.5 turns. I am running with no airbox lid and a Noleen racing pipe with oversized head pipes with the WB rev limiter. It's running real strong in 2nd and 3rd.
Old Jul 12, 2000 | 05:14 PM
Trxoutlawz's Avatar
wideopen,
Raise your clip (lower the needle) one notch. Sounds like your running a bit rich in the mid range.
Later,
Chuck
www.trxoutlawz.com
'00 400ex
'99 426ex
'99 Banshee
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
