250R throttle help??
Old Mar 18, 2004 | 05:17 PM
TrxR's Avatar
Default 250R throttle help??
I got a 87 250R and the throttle has way too much play. I tore it apart and it is completly wore out inside. Does anyone know the part number for the complete unit or know of a good aftermarket replacement??
Thanks
Old Mar 18, 2004 | 06:31 PM
bansheeesmoker's Avatar
THUMB OR twist, bansee ones work good, it's a easer pull because it was made for 2-carbs.
Old Mar 18, 2004 | 06:45 PM
DaBeechMan's Avatar
Not really, the 250r throttle assembly has a gear reduction in it.
what part is worn out on it and ill try and find it for you
Old Mar 18, 2004 | 07:13 PM
[img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 19, 2004 | 11:39 AM
TrxR's Avatar
pretty well every part is worn out on the inside[img]i/expressions/face-icon-small-sad.gif[/img] I was hopping to get a complete assembly. I found this problem when I couldnt get the machine to idle but if you pull the slack out of the throttle it idled fine[img]i/expressions/face-icon-small-sad.gif[/img]
PS I priced the individual pices and it gets pretty expensive
Old Mar 19, 2004 | 12:17 PM
trx250Rob's Avatar
You could find a good used assembly on ebay for a good price but on another note, you shouldn't have to have tension on the throttle cable to make it idle. The idle should be maintained by the idle screw, this is usually an indication that your pilot jet is too rich or your air screw needs adjusting. The cable should have slack.
Old Mar 19, 2004 | 01:17 PM
TrxR's Avatar
I just installed a 42 pilot and it didnt seem to help and my air screw is set at 1&7/8 turns out. The idle screw dont seem to do anything [img]i/expressions/face-icon-small-sad.gif[/img] I guess ill have to keep playing with it[img]i/expressions/face-icon-small-sad.gif[/img] It seems to run great just wont idle. I am at 1000' above see level and temps between -10 and 0 celcius jetting is 42 pilot 160 main mods are .060 over aftermarket pipe and open air box with foam filter. If anyone has any suggestion let me know
Old Mar 19, 2004 | 05:53 PM
DaBeechMan's Avatar
If your having to pull out slack you could either have a bad cable that is old and worn out or maybe a collapsed slide spring in the carb. Check em out. Possibly just lube the cable and if your lucky that may fix your problem
Old Mar 19, 2004 | 06:53 PM
TrxR's Avatar
DaBeechMan: are you saying that a bad cable could be causing my idle problem?? I did happen to find the parts I needed for my throttle on a parts illustration.
Old Mar 19, 2004 | 07:17 PM
DaBeechMan's Avatar
depends on how the thing feels, but it could be yes.
A new billet throttle only costs 90, so keep that in mind if you do decide to go that route
