Adding 20 inch tires in the rear do I need to change the front?
Old Jul 14, 2000 | 02:01 AM
Chris0007's Avatar
Adding 20/10/9 tires in the rear because they fit the stock rim. My question is do I need to change the front stock tires which are 22/7/10 to 20/7/10 or does it matter? Does 21/7/10 fronts work with 20/10/9 in the rear?
Old Jul 14, 2000 | 08:37 AM
hondatrx300ex's Avatar
yea you can put what size tires you want on front.......smaller or bigger than the back it doesn't matter
Old Jul 14, 2000 | 10:09 AM
Lurch77's Avatar
Chris, I assume you have a 2 wheel drive. If so, hondatrx300ex is right. If it is a 4x4, then you will have to be more careful.
Old Jul 14, 2000 | 08:21 PM
Chris0007's Avatar
Lurch I have honda 300ex
Old Jul 14, 2000 | 08:45 PM
Lurch77's Avatar
Ok, then you will have no problem switching sizes on the rear tires, and leaving the fronts alone.
Old Jul 14, 2000 | 11:45 PM
yea I just figured not many people are gonna put 20" rear tires on a 4x4. later
WilliamBos
Sep 30, 2015 08:08 AM
bonanza 440
Jun 26, 2015 10:01 PM
MrElussive
Oct 26, 2000 02:30 PM
Rancheres4X4
May 5, 2000 02:09 AM
