Trick 250R
Old Jul 16, 2000 | 12:05 PM
bubbagodkin's Avatar
Hello,
This monday I will be picking up my new 86 250R
And then I will begin modifications over the winter, anyway I would like to know what ever one thinks would be some cool mods. These are the ones that I plan on doing.
-Black Standard Maier plastic
-red renthal bars
-Fmf Fatty pipe (not sure if I should get this one because I want one that is Mid-Range)
-holeshot Tires front, Rear
-Get the frame/swingarm painted at a shop bright red again.
-Get the rear Shock rebuilt, and get dual rate Front shock units.
-A pro-Design Cool head, can I get one that works with pump gas.
Anyway thanks
BUB
Old Jul 16, 2000 | 01:37 PM
Backcountry's Avatar
I absolutely DESPISE my Maier plastic. It was the worst thing I have ever done. The fit and finish is CR@P!!! Granted it is much cheaper than OEM plastic and you have a better range of colors, I still don't like it. The plastic is much softer too, so it scratches easier too, and with black, every little scratch shows...
The Fatty tends to have a little more of a hit towards the mid-range, which can cause wheel spin. A pipe like the CT national, LRD MX, or Paul Turner mid-range, have a mellower hit, but still provide very nice power.
You can get Pro-Design domes to run with just about any fuel you desire.
Old Jul 16, 2000 | 04:57 PM
trcagle's Avatar
i think that the maier plastic is good-
i have it on mine--"mop and glow" work wonders on it..
i would recommend that you get the frame power-coated, and not painted..
i think that good suspension ought to come before
a "hot" motor.. i have PEP triple rate motos on mine
as far as a pipe goes, i think that the LRD is the best-- it is the only one that i know of that is
~adjustable~ so you can "tune" it for low, mid-range, or high end---
email me if you want specs on the LRD pipe
thats my thoughts
fill 'er up and let's go!!
Old Jul 16, 2000 | 09:17 PM
400exalltheway's Avatar
yeah i like maier. thats what i have on my 400ex and ride trails and race and don't see any straches. i think it is a hard plastic and pluss there is a one yr. warrenty
Old Jul 16, 2000 | 10:04 PM
94DGblaster's Avatar
i like maier plastic, mine is nice..fit isn't the best.
Old Jul 16, 2000 | 11:50 PM
I guess alot of it has to do with where I ride at--the dunes. Most everyone has everything polished or chromed, custom paint jobs, most bikes are showcases. No matter how much chrome Lonestar stuff or Cascade billet goodies I have, my plastic still looks like S$!T...
If I rode in the mud or tight trails alot, and didn't want to fork out the cash for OEM fenders, then...yeah Maier would be OK.
Old Jul 17, 2000 | 05:23 AM
chriscoll1's Avatar
I say dont get an FMF pipe.Pick an engine kit you like from a good tuner(CT,Duncan,Sparks etc)and get the pipe for it.If you can afford it get the whole package(carb,porting etc).A steering stabilizer works wonders too,the best $100 you'll spend.18 inch turf tamers on 8 inch beadlocks,radials up front.Axcalibur +4 axle is also a must have.Bigger a-arms wont hurt either.Gettin carried away here he he I love building these things!
Old Jul 21, 2000 | 11:44 PM
250Racer's Avatar
Maier is alright. Stock is still better. As for the powdercoat paint, your call I get mine done at work with regular automotive paint, my buddy mixes with some addative that allows the paint to, you might say give a little. It may not hold like powdercoat but heck it gets redone once a year. Go with a CT pipe get the MX style its got awsome mids. Cool heads are nice, if you like a 250 or just save some more pennies and but a CT 310 for it. Very awsome usable power. Shocks, get the rear revalved and a set of works perf will be just fine up front. As for the holeshots......I like Fast trekkers all around 21x7x10s up front and 18x11x8 in the rear. Gearing is 14front 38 rear.
250Racer's Avatar
'86 250R
lots and lots of mods
to many to list
Old Jul 23, 2000 | 12:47 AM
JD250R's Avatar
If you paint your frame use Nason Holly Red urethane paint. It matches stock red plastic almost perfectly. I have this on my '88 frame for over a year now & there is just scratches by the footpegs from my legs.
snake99
Sep 30, 2015 07:31 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
CRamshaw777
Jul 18, 2015 05:46 PM
