No power in 6th
Old Mar 29, 2004 | 08:52 PM
powerslider's Avatar
Default No power in 6th
The 22" rears are robbing power, 20's are stock size. Your top end is ready for a rebuild 150 is min, 165-170 is normal. The tires and comp are why it won't pull 6th...
Old Mar 29, 2004 | 09:37 PM
dragracer789's Avatar
^ exactly..... By the way if you put smaller LIGHTER rear tires on and rebuild it you will 1- have more get up and go, 2- will be faster threw every gear. I WOULD NOT put a 45 tooth on the back!! In general you would have better luck with changing the tires, and rebuilding it or at leat puting on a thiner head gasket (raises comp.)...
Old Mar 29, 2004 | 10:08 PM
HughJazz's Avatar
I am at 3000 feet above sea level. That may afffect the compression. Why wouldn't you go with a 45 tooth on the back? I can't go with tires any smaller, i do lots of riding in mud and muskeg and climbing the side of mountains, once a year i go to the dune in St. Anthony. I thought a bigger sprocket would be better because sand is so power robbing. Where is the compression limit for 92 octane gas?
Thanks for the input so far.
Old Mar 29, 2004 | 10:27 PM
True your altitude will lower the comp reading but your still giving up hp, on 92 octane you can run 170psi. The gearing change is huge going from a 39 to a 45, you won't have a very high top speed but it will surly pull 6th gear..
Old Mar 29, 2004 | 11:11 PM
  #15
pimp250r's Avatar
Yes, 6th gear at 40mph probably lol
Are you sure you can't goto 20's? Is there a skid plate on your R?
Old Mar 30, 2004 | 12:50 AM
  #16
bansheeesmoker's Avatar
it would cost half as much to buy a counter shaft sprocket than a rear sprocket. 22's is too tall for your gearing to pull 6th, go down to 20's or buy a 11-or-.12 tooth front sprocket $25 bucks.
Old Mar 30, 2004 | 01:43 AM
  #17
HughJazz's Avatar
I have been told that running a smaller sprocket on the front will where the chain out faster. I think it will go faster that 40mph. 3 teeth on the back should equal in increase in tire size from 20 to 22. So really all I am doing is gearing it down 3 teeth from stock. I run 12/44 on my raptor with 22inch tire and it goes plenty fast enough, It was 13/40 stock. After I do some motor work to it I may just goto a 41or 42 on the back.
Old Mar 30, 2004 | 03:36 AM
  #18
DaBeechMan's Avatar
if your biking is laying down on the top you could be lean.
86-89 gear ratios only changed from 3rd to 4th. 88's had a different spread
Old Mar 30, 2004 | 04:05 AM
  #19
oh,dabeachman proves me wrong again. I learn something new every day. Maybe I should stop posting[img]i/expressions/face-icon-small-frown.gif[/img]
Old Mar 30, 2004 | 08:49 PM
  #20
pimp250r's Avatar
^^ yeah, no kidding. DaBeechMan - why do you always come in 'ere an be all smart n stuff
[img]i/expressions/face-icon-small-smile.gif[/img]
