No power in 6th
Old Mar 31, 2004 | 03:45 PM
  #21
cals400ex's Avatar
Default No power in 6th
make sure your not too big on the mainjet. that will kill your top end power too along with those tires. most people jet too big so they run a little rich. this helps with cooling but robs power.
Old Apr 3, 2004 | 08:47 PM
  #22
CrAcKhEaD's Avatar
My 6th gear used to suck also but as mentioned b4 a port and polish will correct that problem quick status! I currently have 13/36 with 18'' tires and 6th pulls just as hard as 1-5th.
Old Apr 5, 2004 | 05:58 PM
  #23
dragracer789's Avatar
Just for the record, the 86/87 SIXTH gear (mabey 5th too) was diffrent from the 88/89.The gear ratio was slightly diffrent. Thats why the older R's had more trouble pullin the last 2 gears than the 88/89 did.
Old Apr 5, 2004 | 06:32 PM
  #24
blue250r's Avatar
Check out this link to a gearing - ratio chart, it should help u see how much of a change u will be making
http://www.sidewindersprockets.com/images/ratioa.gif
Old Apr 6, 2004 | 01:08 AM
  #25
HughJazz's Avatar
Thanks for the help I getting it ported and polished rite now. So I'll see how it prefrom after that
Old Apr 8, 2004 | 07:23 PM
  #26
250R4LIFE's Avatar
That's right. 1st thru 4th is the same on all the 86-89 bikes. The 88-89 bikes changed 5th & 6th gear to a lower gear ratio. It's easier to pull 5th & 6th on a 88-89. When you hit 6th gear on the 86 with stock gearing, It almost feels like overdrive. I know a lot of people who have had ESR change there 86-87 bikes trannies with the 88-89 5th & 6th gear. My 86 with just pipe, fresh motor & Sand skate 2's had to have 12/40 gearing to pull 6th gear in the sand on a long straight.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
