300EX reverse RPM limiter
Old Jul 17, 2000 | 01:15 PM
94DGblaster's Avatar
Is there a way to bypass this thing?
I want to do away with every unneeded wiring part there is.
Thanks
Old Jul 17, 2000 | 04:15 PM
426ex's Avatar
buy a rev box or send yours away. to eliminate the rev limiter.
426ex's Avatar
buy a rev box or send yours away. to eliminate the rev limiter. about $100
Old Jul 17, 2000 | 04:41 PM
i didn't mean the RPM limiter for forward gears..
For reverse!
Old Jul 17, 2000 | 05:39 PM
Y2K300EX's Avatar
Yes you can get rid of it. There are only 2 ways that I am aware of, I only know the one. On the right side, near the rear brake lever, there is a cover. Take it off, then unhook the forward most wire(I think thats it, if not put it back and and try the one behind it) and hold it to the motor. Then shift into reverse and try to start it, when you figure out which wire it is, then you can permenently ground it on the motor. Thats how to get rid of the reverse limiter.
Old Jul 20, 2000 | 11:11 PM
exlax250x's Avatar
you dont ground it you have toi make sure it isnt touching thestud that you took it off from thats the easist way
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
