i need help from 400ex riders or others
ok i have the stock sprokets on the ex now but i want more power in the bottom and midrange so if i put a sprocet with 1 less tooth on the front how much power will i gain and how much speed will i lose
the 440 kit would be really helpful, but if your on a budget you could get a 416 kit installed with a JE high compression piston and a cam and you wouldnt need to change sprokets.
I did this mod once because I was running Holshot XCT's which are 22". Didn't keep it for long......way to much torque! The front end was pointed at the sky all the time. I would lose steering control powering out of corners. Finally settled on one tooth bigger in back as the best compromise.
Sep 30, 2015 01:37 AM
