axle bearing removal 400ex
Old Apr 10, 2004 | 08:12 PM
scaryfast18's Avatar
Default axle bearing removal 400ex
I have tried almost everything to get the 2 axle bearings out of the bearing carrier but they just wont move. Anyone done this before on their own. If so, please help me out, im about to just buy a new carrier. Thanks
Old Apr 10, 2004 | 10:59 PM
Quadfather's Avatar
I heard a trick many have used with success. Put carrier in oven at 250 degrees for about twenty minutes. Bearings will fall out.
Old Apr 10, 2004 | 11:15 PM
300exRiderJay's Avatar
Wouldnt that damage the carrier? I mean, it's only cast alluminum. I just got a new carrier for my 300ex, because mine cracked somehow which ended up causeing the bearings to go. stock ones are 220 with bearings installed for a 300ex so they are probably the same for a 400ex. What got me mad is that i saw an aftermarket one online for 150 after i ordered the stock one from my shop.
Old Apr 10, 2004 | 11:18 PM
NotuRaptor2's Avatar
You can also heat the carrier with a torch and tap them out. It will take about 5-7 minutes per side of heating with a propane torch. Don't think 10-15 seconds of heat is going to do the trick. Pretty much, it is hot enough when you can't pick up the carrier with your bare hands on the opposite side.
Old Apr 11, 2004 | 12:07 AM
Thanks for the help. Ill try heating it up, see if that does it.
Old Apr 11, 2004 | 03:36 AM
hoover7's Avatar
air chisel
Reactant
Mar 30, 2022 02:08 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
Rider252
Jul 6, 2015 03:37 PM
