250r engine in 250x...possible???
Old Apr 14, 2004 | 10:41 AM
250xRKrider's Avatar
Default 250r engine in 250x...possible???
i am just wondering if a 250r motor will fit into an 87 trx250x frame? i'm guessing it will require some modifications and machining to the frame and brackets, but is there anything that i should look out for, and is this an easy or hard modification?? i want to do this b/c i can't offord a whole 250r, but can i rather just get the engine and put it in my 250x instead??
Old Apr 14, 2004 | 11:44 AM
trx250Rob's Avatar
It probably will fix because the R motor is smaller and lighter, the main problem is mounting the radiator.
Old Apr 14, 2004 | 12:55 PM
Lancester's Avatar
Figuring out a way to start it might be an issue.......
Old Apr 14, 2004 | 01:33 PM
cRazyJ's Avatar
it can be done, i saw one in the cycle trader, sain it used the stock pipe without bending it or anything, it cleared the frame
Old Apr 14, 2004 | 10:32 PM
THEXOTIC1's Avatar
My Question is why you would do that? The 250x is not a frame for that motor the suspension isnt great . Look for a 250R roller and put the motor in that.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
CRamshaw777
Jul 18, 2015 05:46 PM
