400ex - air box lid.
Old Apr 15, 2004 | 10:32 AM
SANDMAN430's Avatar
Default 400ex - air box lid.
the lid from powroll already has the holes in it so then you would have your stock lid for those rides that there is a lot of water
Old Apr 15, 2004 | 02:08 PM
400EXTC's Avatar
Originally posted by: 400excrazy
If you get a k@n air filter and prefilter is rely the only time you sould take your air box cover.......or jet it but the stock air filters are not good enough to stop all the dust and dirt.
I'll have to argue that a k& n filter filters better than a stock filter. It makes more power because it allows more air to pass through. Guess what, more dirt too. You can nearly see through a k&n if you hold it up to the light. I will agree the prefilter might be more effective at protecting the filter from water, but not dirt. Otherwise honda would use a similar design if it was superior.
Old Apr 15, 2004 | 02:11 PM
400EXTC's Avatar
I'm not knocking K&n filters i have one on my quad and my supercharged mustang.
Old Apr 15, 2004 | 04:04 PM
Eric250EX's Avatar
this may sound dumb but i took my whole air box out or my 400ex, i got a k&n and outerwear for it. and for the pvc hose, you know the hose that blows out aire when shifting that usualy goes into the airbox, i just ziptied that to the fram (does nothing now just blows out aire). i only did this b/c i ride on farm land. if u ride in woods and mudd i strongly sugest u just take off the lid and get a K&n filter w/ outerwear. but anyway i could tell a big difference in the accel. but then i got my sparks pipe and it runs real well.
Old Apr 15, 2004 | 08:17 PM
  #15
orky4969's Avatar
so you guyz suggest buying a K&N air filiter w/ the outterwear and just leave my lid off.... then when i go places where it's wet just slip my cover back on? -- is it worth the money to do this... as in do i notice the power differ/?
Old Apr 16, 2004 | 05:00 PM
  #16
400excrazy's Avatar
along with the prefilter you can also purchase a k@N air box cover that also helps alot
Old Apr 16, 2004 | 05:04 PM
  #17
400excrazy's Avatar
EHS racing makes an awesome air box cover check it out www.ehsracing.com ITS CHEAP!!!!
Old Apr 16, 2004 | 06:52 PM
  #18
orky4969's Avatar
it says that it's recomendd to run w/ jetted quad... should and can i run my quad w/ those w/o changing the jets?
Old Apr 16, 2004 | 06:54 PM
  #19
orky4969's Avatar
the above statement i made i am talking about 400excrazy's link to the air filters.
Old Apr 16, 2004 | 06:57 PM
  #20
400excrazy's Avatar
if it says to run with a jet than thats what u need to do in the web it said what jet u need
400EX CRAZY!!!!
