400ex - air box lid.
should i take the airbox lid off of my 02 400ex? or is it not worth it... and also is the power a noticeable different? i heard it gains you about 1-2 H.P. i dont know if thats true or not.
I wouldnt take the lid completly off.. I found a better way that works very well without having alot of trash in your airbox.. Take a coffee mug put in on to (toward the rear)use a marker and circle the bottom of the mug then take a 1/8 drill bit and drill holes about every 1/2"on that marker line then a couple hole in the middle of that circle..I did that and put a 155 main jet in and you can tell a difference...Hope that helps
im thinkin bout puttin hole in my lid. if i do that will water get in. i ride through some mud and water. also will the water stay out if i just drill the holes and put some of them little filters that they sell?
if you dont have your EX jetted then takin the lid off will only hurt your power, it messes up the whole gas/air mixture thing, a 155 main sounds good, then take the lid off...but i would also suggest a k&n filter with the precharger to keep dirt and debris out
It is very easy to do and costs under $100 easy...I would buy a K&N with the outerwear(a skirt that goes over the filter to keep dirt and water out) $40-$50 for filter and a 155main jet $5 holes drill in air box Priceless..lol...It will make a big difference in your Throttle response and power..It is worth it....
Keepitpinned...I went though alot od mud and water this weekend and have maybe a couple of drops of water.. not enough to do anything...NOTE.. I would suggest a K&N and outerwear prefilter (the prefilter will also help with any debris that would get in through the holes).. Also a pair of pantyhose over the lid will help with mud and water from getting in.. Sounds funny but it works...
