POWERBAND
Old Apr 14, 2004 | 10:10 PM
keepitpinned's Avatar
Default POWERBAND
How and what exactly is a powerband?
Old Apr 15, 2004 | 12:14 AM
CrAcKhEaD's Avatar
Default POWERBAND
A powerband is the point in which an engine makes peak power.
Old Apr 15, 2004 | 12:27 AM
Default POWERBAND
what atcually happens inside the motor to make this happen
Old Apr 15, 2004 | 12:55 AM
CrAcKhEaD's Avatar
Default POWERBAND
intake, compression, power, and exhuast all at a very fast rate[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 15, 2004 | 12:56 AM
orky4969's Avatar
Default POWERBAND
yah what he said -- mainly 2-strokes have a powerband.... at least there 80% more noticeable in 2-strokes
Old Apr 15, 2004 | 08:34 AM
PomroyTheBikerboy's Avatar
Default POWERBAND
i got a dirtbike with a powerband, im twelve and the dirtbike is a cr 60
Old Apr 15, 2004 | 12:21 PM
Default POWERBAND
i thought it was when the reeds open quicky at a certain rpm? can anybody explain it
Old Apr 15, 2004 | 12:25 PM
FarmStud's Avatar
Default POWERBAND
Maybe your thinking of a powervalve?
Old Apr 15, 2004 | 02:17 PM
Shav0's Avatar
Default POWERBAND
There is no physical piece in your motor that you can take out and replace. It is simpily a word to describe how the power is transfered to the ground. For example, Have you ever rode a banshee? You can be driving around and not doing too much and then when you open it up it just explodes and takes off. This is because the banshee has a high powerband and makes most of its power in the top end. Most bolt on modifications you can get for a quad moves the powerband to lower rpm's, or higher. A pipe for example changes the length of the powerband. This is why each pipe is different and produces different types of gains.
Old Apr 15, 2004 | 04:58 PM
hondaracer305's Avatar
Default POWERBAND
Well, theres different types of powerbands, blue, yellow, green, white, purple, orange, pink, red and black. The black powerband makes the most horsepower, i have 2 of them in my banshee, its real fast with the valve bearings [img]i/expressions/face-icon-small-wink.gif[/img]
