440ex Top Speed/race fuel
Now i am running straight 110 race fuel, with dj1770 main jet in. I checked my plug, seems to be running hot, because it was light gray to white...Should i turn the screw alittle, or should i change the main jet or what i should do. Thanks
you need to tell us the plug color after a full throttle run and then shut the bike off and pull in the clutch when maxed out. the plug readings aren't the best thing to do these days. its just tough to read. i doubt the 170 DJ is too lean.
Elkaholic
Sep 6, 2015 02:44 PM
