Who makes the best air filter?
If you know how to oil your K&N and use a prefilter it filters better than any foam filter does plus gives you alot more air flow which means more power! And why would you make a comment about it not filtering anything????
A Uni is already a 2 stage filter (2 separate layers of foam). It's OK to run without the lid unless you're hitting a lot of water. Don't cut down on filter cleaning intervals. This is one of the most important things to do to help the engine life and performance of your quad. Keep it clean and use a spray on oil like PJ1.
bpegram84
Jul 22, 2015 08:15 AM
