400ex Swingarm Bolt!!
Old May 7, 2004 | 07:11 PM
MidLifeRider's Avatar
Default 400ex Swingarm Bolt!!
While pulling my engine the other day, everything was going really smooth until the last bolt!
The swingarm bolt. Man I beat on that sucker, heated it up with a torch, beat on it some more broke a ratchet. That sucker was froze, I finally ended up cutting a section out of the right side and was able to scoot the motor over just enough to cut the other side with a torch. But what a hassle! I still have a section of the bolt froze in the motor, I am keeping it lubed up with some WD and hope it will brake loose. Otherwise I guess I will drill it out if it is not hardened steel! What a way to ruin an easy engine swap.
Old May 7, 2004 | 10:26 PM
URCRAZY's Avatar
Yea good luck, it is a hassle. I bought a stainless steel main bolt and lubed it with anitseeze, and it was still hard to take out after 1 year only. I say keep it lubed and heat it again and try getting it out. Drilling it out might cause a off hole and misalingment.
[img]i/expressions/face-icon-small-frown.gif[/img]
Old May 7, 2004 | 10:29 PM
RedNeckMXRider2's Avatar
order some AeroKoil it works really good on freeing things up
Joe454
Nov 20, 2020 01:19 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
