250R engine building
Old May 11, 2004 | 07:13 PM
Evokiller's Avatar
Default 250R engine building
I have an 1986 TRX 250R with blown engine. The rod bearing went to hell. I'm going to rebuild the engine myself because I'm Financialy challanged. Here are the components I have to deal with. The cylinder is in great shape and ported for mid range and top end. I run a 38mm Kiehin air striker. The pipe is an ESR TRX11 top end drag pipe. New stock ignition. Trans and clutch are perfect. Here is my question.
The 1986 runs a short stock stroke. Can I install a +4MM stroker crank and use the stock cylinder that has been ported for the shorter stroke?
Do I need to run a stroker plate under my stock cylinder if I do this and what thickness is required.
Do I have to port the cylinder for the stroke change I think it has been taken to the limit already?
Can anyone give me a list of matching components to have the correct deck height with the a stock cylinder.
Glenn
Old May 11, 2004 | 07:47 PM
Sm0k3d's Avatar
What I understand is you won't have to change your porting, but you will have to have a 4mm spacer plate for the 4mm stroker crank. I am not sure whether you use a 1986 piston or a 88-89 because i believe there is a difference.
Old May 11, 2004 | 08:22 PM
Evokiller's Avatar
I believe your correct about the piston because the pin height would have to be higher and the piston would have to be shorter. What I don't know is why there are (2) types of cylinders used in 86. There is an (A) and a (B). I have a cylinder stamped with a (B). I also don't know why there are like (3) different parts numbers for cranks used from 87-89
Thanks
Glenn
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
CRamshaw777
Jul 18, 2015 05:46 PM
