Ne one ridden a CR500????
ya those bikes are great, but when you put in an atv frame the vibration gets reeaal bad. im not sure where 1 saw it but with a little modifying you can bolt the cr500 jug rite up to a 250r bottom end, i think.
it might hve been atvsport mag or dirtwheels.
o ya i forgot to say that the 250r bottom end is used because it has a counter balancer and that gets rid of most pf the vibration
#15
thanks Eric . the bad thing about mounting a cr500 cilinder on a 250r is that the clutch and trannie never hold up (and its very costly). The 250r trannie and clutch is actully from a 125 dirt bike motor and the cr500 is from a 250r dirt bike. There is a new power valve 500 cilinder kit being tested that bolts on to the 250r bottom end.
