300EX wheel bearings ?
Old May 26, 2004 | 08:54 AM
Trevor's Avatar
Default 300EX wheel bearings ?
Should there be a little play in the front wheel bearings or should there be no play at all?
Old May 26, 2004 | 03:17 PM
hondaracer305's Avatar
I dont think there should be any. If there is, it will usually start wobbling at higher speeds.
Old May 26, 2004 | 03:24 PM
Trevor's Avatar
It's not that much it is just enough that when you wiggle the wheel you can hear and feel it!
Old May 26, 2004 | 05:17 PM
I think mine does it too so i guess your alright.
Old May 26, 2004 | 05:26 PM
highflyinHonda's Avatar
Your probably fine for now but you might want to change em soon
Old May 26, 2004 | 05:27 PM
dragracer789's Avatar
Well its not going to hurt it. Just think if it was any tighter you would go slower, and wouldnt gain anything.....
Old May 27, 2004 | 08:41 AM
Trevor's Avatar
I'm going to see if I can get some bearings and brake pads of E-Bay
Old May 27, 2004 | 05:30 PM
LocknLoad's Avatar
take the cotter key out of the castleated nut and see if you can tighten it some, and put the pin back in. Your hub may be loose on the splines and just need tightening some. I have had to do this on all our quads from time to time.
Old May 28, 2004 | 08:47 AM
Trevor's Avatar
I'll give that a try this weekend!
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
