TRX70
Old May 31, 2004 | 03:34 PM
sano's Avatar
Default TRX70
I am in need of some information on mounting tires on a TRX70 split rim. They have o rings as seals and bead sealer on them. Do you have to replace the over priced o rings or is there a better way? Any suggestions or links would be appreciated...thanks...Jim
Old May 31, 2004 | 09:16 PM
Eric250EX's Avatar
Default TRX70
it might be easier now and in the future if u just get a tire already mounted on a single rim made for the 70
Old Jun 1, 2004 | 10:38 AM
quadwrench's Avatar
Default TRX70
Wash the old "O" rings up with soap and water, dry them off, clean up the "groove" in the rim and lay a thin bead of RTV silicone in the groove, put the "O" ring in the groove and bolt the rim/tire assembly together. - - put some soap on the tire beads to make it seat easier. I've never had to use a bead sealer on these wheels.
Old Jun 1, 2004 | 11:25 AM
sano's Avatar
Default TRX70
Thank you for your input. I will give it a try!
Matt8110
Mar 22, 2015 01:39 PM
bills56f100
Jul 28, 2010 05:52 AM
Maddog11
Oct 27, 2008 11:50 AM
pugads650
Feb 5, 2007 03:07 PM
rumblefish1973
Jan 26, 2003 11:36 PM
