98 Foreman 400 questions
Old Jun 2, 2004 | 08:15 PM
kayden's Avatar
Default 98 Foreman 400 questions
I have recently bought a 1998 Foreman 400 and the rear brake pedal is completely seized. I've heard that you can heat it up with a torch to loosen it up and get it working again. Has anyone done this before ? In my manual it shows dust seals inside the pedal, are these all made of metal or rubber ?
I was also wondering if anyone knows how to test the rad fan, it never seems to come on. I've checked the fuse and it seems fine.
Any suggestions would be appreciated.
Dan
Old Jun 3, 2004 | 01:04 PM
Loster666's Avatar
My 98 Foreman brake pedal was seized too !
I just got it unstuck by pushing and pulling it back and forth ...
Took about 30 minutes .. 8]
Then I removed it and washed the pivot and put grease on . .
But you should be able to get it to move by puting a long rod or a wrench on the pedal and try to move it ..
Old Jun 3, 2004 | 06:53 PM
kayden's Avatar
Thanks Loster, I'll try that. It is so seized that it barely moves when I smack it with a hammer. I heard that heating it up with a torch will help, I'll try that with a long pipe like you suggested.
Dan
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
Johnny Mac
Sep 27, 2015 08:33 PM
patrick.oc123
Sep 16, 2015 03:45 AM
wendal
Sep 15, 2015 01:50 PM
