Installing a Hot Cam
Old Jun 13, 2004 | 11:28 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Default Installing a Hot Cam
Originally posted by: Quadfather
Installing just the cam won't do a whole heck of a lot.
That's not true. If it's like any other 4-stroke, it can make a big difference. You can alter where the motor produces it's power and how much by altering the timing. You may have to add stiffer valve springs. Not sure. The drawback is it may be harder to start and more tempermental. Depending on which cam you choose it can cost you some low end.
OH, how I love that hot cam idle!
Old Jun 13, 2004 | 11:29 PM
Quadfather's Avatar
When I had my 400EX, I put in a JE 10.8-1 416 piston kit ($140), a Hotcam Stage II cam ($125). The boring and honing were around $80 if I remember correctly. I also changed out the valve seals and retainers, around $30-$40.
Old Jun 13, 2004 | 11:34 PM
emac's Avatar
ok, thanx, so for my first bore will i need a new sleeve? or can i just bore out the origional
Old Jun 14, 2004 | 12:32 AM
cals400ex's Avatar
you use the stock sleeve. the stock one will accept up to a 426.
Old Jun 14, 2004 | 08:50 AM
  #15
420EX's Avatar
I didn't like the stage 2 hotcam, spend the extra money and get a Web cam with hardened rockers and stiffer springs
Old Jun 14, 2004 | 08:13 PM
  #16
400sEXridr's Avatar
420ex, what kind and where were the power gains with the webcam
Old Jul 16, 2004 | 03:45 PM
  #17
400sEXridr's Avatar
what does it mean to hone a cylinder
Old Jul 16, 2004 | 05:34 PM
  #18
cals400ex's Avatar
i had good success and power gains with the hotcam. different cams will produce power at different rpms. everybody prefers something different. you can call C&D racing on cams. the # is 308-696-7805.
honing the cylinder is like scratching it up a bit. when installing a new piston or new rings, the cylinder needs to be a little rough for the rings to seat properly. this will provide a good seal and produce a better running bike.
Old Jul 17, 2004 | 02:01 AM
  #19
Ozark38's Avatar
If you run trails, all you need is HC stage 1, a good slip on (not a header), a good filter with no lid, and proper jetting. Excellent low end!
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
