K&N power kit.....worth it??
The K&N power kit consists of a few jets, a tapered needle, a drill bit, and installation directions. It costs $45 dollars. You can see it at the Rocky Mountain ATV website. It is helpful after installing a freer breathing air filter, and its also compatible with a well designed performance exhaust pipe. It allows you to rejet and get the full power gains allowed by filter and pipe.
The K&N power kit consists of a few jets, a tapered needle, a drill kit, and installation directions. It costs $45 dollars. You can see it at the Rocky Mountain ATV website. It is helpful after installing a freer breathing air filter, and its also compatible with a well designed performance exhaust pipe. It allows you to rejet and get the full power gains allowed by filter and pipe.
The kit that is on rockymountainatv.com for $45 is just the jets kit, the actual power kit is $110 and it has the jet kit, a high flow filter, a precharger, and a cleaning kit, I just put a kit on my bayou 220, and I like it alot, it has helped alot on the hill climbing ability, and throttle response, not to mention the jump in top end speed. I would recommend the kit to anyone.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
