250r Major Problems
Old Jun 29, 2004 | 02:01 PM
Eceriderjbomb's Avatar
Default 250r Major Problems
I am in the mountains of PA I guess i will movre the main up.. It ran better when i put a lower jet in
Old Jun 29, 2004 | 04:28 PM
dragracer789's Avatar
Vsandrat- He said that his motor was sputtering and boging with a BLACK plug so he was running rich, plus his motor is stock (no porting). He should be right there with jetting or mabey even have to go lower sence hes still fouling them.
Eceriderjbomb- Ill almost garentee your motor isnt siezed unless your left side crank seal recently went bad.. Sometimes the kicker on the 250R gets stuck so you have to take off the right side cover (as your sitting on the bike) and re mesh all the gears, BUT before you do that i would take drain the antifreeze and take off the head to see what everything looks like. If it all looks normal see if you can push down on the piston and if it moves your motor isnt seized but if it doesnt move (has to be in nuetral) then your motor is probly siezed, or has something to do with your crank assembly. if you have any Q's AIM me.
Old Jun 29, 2004 | 05:58 PM
bansheeesmoker's Avatar
souds like it could be your cdi box. when mine went bad I had to rejet every 5 mins and then it seized because I leaned it it out (same as you) to make it run better.
Old Jun 29, 2004 | 06:46 PM
powerslider's Avatar
Originally posted by: dragracer789
Vsandrat- He said that his motor was sputtering and boging with a BLACK plug so he was running rich, plus his motor is stock (no porting). He should be right there with jetting or mabey even have to go lower sence hes still fouling them.Eceriderjbomb- Ill almost garentee your motor isnt siezed unless your left side crank seal recently went bad.. Sometimes the kicker on the 250R gets stuck so you have to take off the right side cover (as your sitting on the bike) and re mesh all the gears, BUT before you do that i would take drain the antifreeze and take off the head to see what everything looks like. If it all looks normal see if you can push down on the piston and if it moves your motor isnt seized but if it doesnt move (has to be in nuetral) then your motor is probly siezed, or has something to do with your crank assembly. if you have any Q's AIM me.
I guess I'm blind but I don't see any mention in any of the posts about the plug color. Maybe it hydro locked from flooding due to dirt in the needle. That's still a small main jet for a 38mm carb, I'm at 800 ft alt and run a 180 with complete stock intake system....
Old Jun 29, 2004 | 07:00 PM
  #15
HA2's Avatar
HA2
i run a 170 with a ported ext filter and all the other goodies 38mm carb 250 around sealevel.
Old Jun 29, 2004 | 07:10 PM
  #16
so it sounds about right beacuace my plugs where black but i am getging kmy carb cleaned
Old Jun 29, 2004 | 07:18 PM
  #17
Yeah he personally told me about his colors and thats what i based his numbers on, but im running 162 with a very very mild port job in mine with the 38mm at the same evevation.
Bansheesmocker- thats a good point. electrical systems play with peopls heads but that still doesnt explain his kicker siezing up....Ecerider, you should check to make sure your grounded out completly and all eletrical parts are tightly connected.
Old Jun 29, 2004 | 07:30 PM
  #18
YFZracer88's Avatar
your plug would load up and youed start fowling plugs. at least thats what happen to a buddy of mine with his cr 125
Old Jun 29, 2004 | 07:31 PM
  #19
yea your rite I dont think thats what it is. I think he should be jetted at a 162 also. what is your pilot and needle at?
Old Jun 29, 2004 | 09:11 PM
  #20
52 pilot and DDJ needle 3rd clip.
