GPS power on 350 Rancher
The gps unit can run entirely from the 12v outlet on the atv. You should not notice any decreased battery life beyond that which you would have seen without plugging it in. In other words, if your batteries work for 3 hours, they will still work for 3 hours when you unplug it from the atv.
I have a Garmin GPS II Plus. I got a bicycle/motorcycle handlebar mount made for that unit. It does vibrate, but I take most of my readings during our frequent stops. When we plan a trip to unfmailiar trails, I will quite often mark the trails using ExpertGPS then upload the waypoints to the Garmin. There have been a few times that we would never have found the trail without the use of the GPS.
The 12 volt power port on my 2003 Rancher is on only when the ignition is on, so the GPS must use its own batteries when the bike is off. I am thinking of rewiring the 12 volt port so it comes directly off the battery. This will probably work fine until I run my ATV battery down because I left something on overnight, then I will rewire back to the way it is supposed to be!
-Frank
-Frank
#15
I have a magellen 315 and I plug it in to the outlet on my foreman all the time. just like a cigarette lighter in the car. dont worry about it. Just be sure your gps is secure and cant fall off on the trail some where. I usually keep mine in my coat pocket and take it out to check it when I am stopped some where. You can mount it on the handle bars or be creative.
Happy Trails.
Happy Trails.
#16
No if you are running on external power the batteries are not in use. If the plug looses connection a message will flash saying "external power lost" then you are working on batteries. Carry spare batteries just in case. It is cheap insurance. also carry a compass and use both. It saves a lot of guess work.
#18
MeadowlarkFarm
11-27-2019 08:40 PM
Elkaholic
09-06-2015 02:44 PM
Logan Collins
09-05-2015 08:03 PM
