TRX250R riders........I need help!
I have an '86 250R and I just bought a Lonestar steering stem off of a guy who had it on an '89. When I go to install it the bracket below where the tie rods connects hits the steel flap on the frame directly behind where the stem mounts into the frame. Did they change the steering stem between these model years? I also installed a new stem bearing kit whereon the top side I put the bearing in first, then the circlip, and finally the oil seal. On the bottom side I have a dust seal with a spacer in it.......is this set up wrong? Any help is appreciated. Thanks!
This illustration
should help you out. Then click on steering shaft to see how the dust seal, bearing, etc., all go together.
collegefunded250
03-29-2001 10:45 AM
