Parking brake probs......
Old Aug 12, 2000 | 12:41 PM
PADZZ's Avatar
Not that I use it that often, but it's there so it ought a work, but my parking brake on my 400 doesn't work. When I pull in the clutch all the way to lock it in place it works, but when I let the clutch go back it doesn't. I'm sure it's a simple adjustment...so does anyone have a clue or have had this problem?
Thanks, Drew
Old Aug 12, 2000 | 12:45 PM
400exalltheway's Avatar
mine hardly ever worked so i got a block off plate
Old Aug 12, 2000 | 01:04 PM
PADZZ's Avatar
What's a block off plate?? What's it for, how much and why?
Old Aug 12, 2000 | 03:55 PM
c400ex1234's Avatar
Parking brake block off plate:
what is it for: removes the complicated setup on the rear capiler, and removes the parking brake while still allowing the capiler pistion to be pushed in, price 10-12 bucks
Why get one: to save your pads "if you try to adjust it alot", and to create a simplier setup
What else you should do if you get one: remove the cable, and remove the stock clutch lever and perch, and replace with a cr250 "MSR" style clutch lever and perch.... around 30 bucks
Why should you do this: because i did it, and i'm the man. LOL
later
Old Aug 12, 2000 | 04:26 PM
PADZZ's Avatar
C400EX1234....Thanks for the info.....so you are telling me that you no longer have a parking brake??
And are you replacing the clutch cable as well as the lever? What are the advantages of switching the lever...other than it's cool cuz you got one?? Also (since I'm bored at work), how long does that conversion take??? Something the average "joe" could do?
Thanks, Drew
Old Aug 12, 2000 | 05:42 PM
c400ex1234's Avatar
my fellow atver who is bored at work:
YES, Thy parking brake on the capiler is gone, thy parking brake cable hast been banished, and thy Stock clutch lever and perch thou art gone.
the cr250 style clutch and perch is more comfortable, and simpler. However thou dost not have to replace thy clutch cable, for thee stock cable works with a cr250 lever.
and yes it is cool.... why:
1. i have one..
2. easier pull (maybe i'm crazy)
3. more confrontable (so you can confront people with it) J/K i mispelled it confortable (did i get it right?)
However if thy chooses to use the stock clutch lever and perch, you may do that also... but you'll get made fun of in the trails.... (not really but...)
Don't tell anyone, but:
You can purchace packages that contain "block off plate, clutch lever and perch" But i didn't do this because i didn't know how good of quality of a lever and perch i was getting.
my suggestion about the "average joe worker"
i am 15, i know a good bit about quads and dirtbikes, and i put mine on in less than an hour.... But i sealed my block off plate with silicone because i lost the gasket....
If you need help there are 3 things you can do:
1. panik, and light some gasoline you have sitting in your garage
2. e-mail me
3. reply to me
later
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
