250r Axle?
Ok, the stock axles...are they adjustable? How do you tighten the axle nut? I think mine needs tightened but I had no way of knowing because I try to move it it wants to stay still. Should it be right up against the rotor? Mine is like 2 or 3 inches away. I may sound dumb, but I honestly do not know.
Thanks,
Warrior68Man
Thanks,
Warrior68Man
Try to rock your brake rotor back and forth. If it moves it is loose, if you can't move it you're good. It doesn't tighten in, it goes out against a snap ring and pushes the collar in.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
