How do you like kicking your R?
Old Aug 2, 2004 | 01:39 AM
MudStud's Avatar
Default How do you like kicking your R?
I am just wondering how you 450R owenrs like kick starting your quad?
How many times does it take to start?
Hot starts?
I bet it sucks in the mud if your stuck and it kills??
I am wondering because I am ponderinga the 450R...
Anyone making a starter for it? Will honda?
Old Aug 2, 2004 | 01:43 AM
TractorPacker's Avatar
Do you have a balloon?
It is not all that bad. You need to learn its quirks then it starts in one or two kicks. Hot or cold.
Old Aug 2, 2004 | 03:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It's no big deal, once you know the drill...............
Cold Start: Choke on full. Kick it over (never takes more than once, even if the bike has been sitting for a week), then idle it down by decreasing the choke. Nurse the throtle for a minute or two, until it begins to run smoothely.
Normal Hot Start (when the bike has been turned off normally): The bike needs to be LEAN, so NEVER TOUCH THE THROTLE BEFORE OR DURING A HOT START! Pull the hot start lever, kick it over (never takes more than one), and don't touch the throtle until the engine is running. If you hit the throtle, you are going to have to kick it over a bunch of times to clear the carb, and you have nobody to blame for your STUPIDITY, but yourself!
Stalled Engine Hot Start: This can present the biggest problem (particularly if you stall on a track)! A stalled engine will have to much fuel in the carburator, and may need to be kicked a few times to clear it out. Hold the hot start lever (to lean the mixture), but again, NEVER TOUCH THE THROTLE. After that, just follow the Normal Hot Start procedure.
Old Aug 2, 2004 | 08:57 AM
Lancester's Avatar
Hot starts?
It's no problem at all. I kick it once, that's all it usually takes....
Old Aug 2, 2004 | 03:23 PM
QuadAddiction's Avatar
no big deal, come on...
when it cold use choke...
try standing it's much more easier...
my friend had a 83 suzuki dr400... try to start that old fashion beast...
even the owners have a hard time [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 2, 2004 | 03:24 PM
oopsi! correction ! ment DR 500 not 400... [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 2, 2004 | 09:09 PM
The other day I went to ride when it was 90 degrees out. The r wouldn't start at all, prolly ten kicks. I used the hot start and the next kick it fired.
Has anyone else had this happen?
Worst thing it was in front of a Raptor buddy. He teased me for, well till I let him ride it.
Old Aug 2, 2004 | 11:14 PM
twentycharacters's Avatar
here in LA (not los angeles) where it is hot and humid 90% of the time, I did the same exact thing yesterday. it did not want to start with the choke at all. It does seem to start better on cooler days - one or two kicks with the choke on. then the hot start button after that.
my 250R started almost immediately. Thats something, huh - an almost 20yr old bike ready to purr much quicker than my new one...
Old Aug 3, 2004 | 12:00 AM
Kbass's Avatar
It is nice not having to worry about a dead battery, or buying a new one every two years. Kicking it is not a problem.
Old Aug 3, 2004 | 12:24 AM
2StrOkeFReaK's Avatar
Hey 20,
How does that 450 rate with you compaired to your 20 year old junk 2-stroker? I rode one with the HRC kit, piped, and geared before buying my 88. I was really excited to ride it, and disappointed with it after. I just couldnt bring myself to buy a 4-stroke.
