400EX question
Old Aug 8, 2004 | 09:52 PM
honda400rider's Avatar
Default 400EX question
Hey everyone,I have a 2000 400EX with a Jardine exhaust, KN filter, Hot Cams Cam, and supposedly the carb is jetted properly. I just bought it used. My question is, it seems to bog out a bit at the high end of the RPM range, but not quite at the rev limiter. And its fairly hard to pick up the front end. Any tips on something that could be causing this? And what I could do to make 'er run a bit smoother?
Old Aug 8, 2004 | 10:01 PM
TractorPacker's Avatar
Do you have a balloon?
The carb is probably too rich. Open the carb and see what main jet you have. I would guess it should be 155 to 165 but just guessing, not knowing all the info.
Old Aug 8, 2004 | 10:02 PM
The guy said it had a 180 in it I think.
Old Aug 8, 2004 | 10:05 PM
They are $5 a piece, here any way. Go to the bike shop and get a couple smaller ones. You want it so it still revs but don't go too small cuz' lean will burn it up. Check that # first then head to the bike shop.
Old Aug 8, 2004 | 10:07 PM
so maybe pick up between a 160-179...what jet do I have to replace?
Old Aug 8, 2004 | 10:18 PM
Does the jet have the number written on it?
Old Aug 8, 2004 | 10:43 PM
chazekxt's Avatar
a 180 wow way to big my buddy has 04 400ex with white brose e2 slipon and ka n he runns a 170 dino jet in his.
Old Aug 8, 2004 | 11:31 PM
kingofthemudholes's Avatar
yeah you can buy those jets in singles for like 3 bucks at www.denniskirk.com
i run a 155 but i dont have hot cam
Old Aug 9, 2004 | 12:10 AM
The main jet is the one you need to change. The # is on it, hard to see sometimes but there. They normally don't go every #. It's like 155, 158, 160, 162, 165............. I would say a 160, and the next 2 up from there. If it bogs down on top end usually rich. If it gets hot or pops, it is usually lean(needs more fuel).
Old Aug 9, 2004 | 09:31 AM
Will I have to change the jet for winter riding?
