rancher valve adjustment
Old Aug 22, 2004 | 03:35 PM
LittleBill's Avatar
Default rancher valve adjustment
when doing the valve adjustment, is it required to get a new head gasket? my book doesn't specifiy
Old Aug 22, 2004 | 10:37 PM
hondabuster's Avatar
How were you planning on doing the adjustment? The head doesnt need to be removed.
Heres an article on doing a generic valve adjust. valve adjust
Old Aug 23, 2004 | 12:29 AM
Specta's Avatar
Honda recommends replacing the "valve cover gasket". I do believe they call it a "head gasket" too. I replaced our when iadjusted the valves. Why do the job twice if the old one leaks oil?
Old Aug 23, 2004 | 01:04 AM
LittleBill's Avatar
i meant the valve cover, it doesn't leak oil, just need to adjust valves? does it get destroyed when taking it off?
Old Aug 23, 2004 | 12:06 PM
Specta's Avatar
It does not get destroyed, it is just a "crush to seal" type of metal gasket. They are not very expensive. I may be over kill, but I replace the two o-rings on the oil filter cover and the aluminum drain plug gasket every time I change the oil. I don't like oil leaks and it is not worth the extra work to go back and replace them if they do.
Old Aug 23, 2004 | 10:52 PM
quadsnmud's Avatar
Just did the valve adjustment on both of my bikes and reused the old gaskets and it went fine, no leaks. Be careful I guess and hopefully your lucky. If your worried as there is alot of plastic to take off again should you have a leak then buy a new gasket......but that is no guarrentee either!
donintennessee
Jan 8, 2021 12:40 PM
Hankey Pankey
May 1, 2018 01:33 PM
rawbdiggity
34
Sep 2, 2015 02:16 AM
Hankey Pankey
Aug 17, 2015 05:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
