wiring warn winch foreman450s, Ideas?
Old Aug 24, 2004 | 12:21 AM
acman2u's Avatar
Default wiring warn winch foreman450s, Ideas?
Hi, I just mounted new warn 2.5ci to my 02 foreman450s. I am trying to determine best place to mount the contactor. Tool/glove box looking real good right now as possibility, also any preferred wire to tap into for the switched wire, good place to tap in? if any one has installed one into another foreman any advice would be appreciated.
Thanks
Old Aug 24, 2004 | 12:31 PM
Live2Mud's Avatar
I mounted the same winch on the my rancher, you want the contactor to stay somewhere were it will be dry, so the tool box is a good place although you will have to take the toolbox off to mount the contactor. I spliced my switch wire into the key ignition, that way if the key is off you dont have to worry about the winch having any power to it.
Old Aug 26, 2004 | 05:28 PM
butch1234's Avatar
take out your fuse box under your seat there is a spot ther for the contactor pad also there is a red wire going to your ignition to splice for a live.
Old Aug 26, 2004 | 09:01 PM
framer's Avatar
Mounted the same winch on my 02 350 a couple of weeks ago.I put the the contactor in the tool box ,perfect spot. Stays dry and was very easy to mount.Had to take the tool box itself off the bike to mount the contactor ,but was only about 15 min.
Old Aug 27, 2004 | 12:22 AM
OleYama's Avatar
Purchased 2004 Honda Foreman ES with 2.5 Warn in March. The dealer installed the box in the back right of the bike, on top of the toolbox.
KimSJoh
14
Jul 18, 2015 07:20 PM
toonces
Jul 11, 2015 12:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
cornermike
Jul 8, 2015 11:44 PM
D-Hagz
Jul 4, 2015 02:19 AM
