Xr experts, please help
Old Aug 26, 2004 | 01:30 PM
elraptor02's Avatar
Default Xr experts, please help
on my 2002 Xr 200 the clutch takes forver to engage..like the dirtbike moves slowly then gets going faster and faster then it fully ingages like 250 ft away from where u started??
Old Aug 28, 2004 | 05:39 PM
honda400rider's Avatar
Sounds like something might be slipping. If able, pull apart the clutch and make sure everything is sound. Then try adjusting at the handlebars and where the clutch cable attatches to the bike at the crankcase.
Old Aug 28, 2004 | 08:13 PM
WVatvRider's Avatar
I have owned several XRs..
Let me ask you a couple of questions.....
1)have you recently switched to a new oil.....switched to synthetic?
2)How recent is your last oil change?
If you have recently switched to synthetic drain it out and refill with dino oil and see if that fixes it.. you may have an old glaze on your clutch plates and the new oil is too slippery.
If you havent changed your oil in awhile, do it and see if that helps.
One last thing to do if those 2 dont apply....I have done this, and many will disagree, but it saves you from opening the engines..
Drain the oil and put in 2 quarts of kerosene and let it sit for an hour or so, move the clutch in and out while going back and forth in gear (NOT RUNNING)!!! just let the clutch plates clean in the kero.
Drain the kero and leave bolt out overnight.
If that works, your plates were just overly glazed and you should be good to go now with a fresh oil change.
If it doesnt work......You need new clutch plates.
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Elkaholic
Sep 6, 2015 02:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
rjacree
Aug 3, 2015 10:21 AM
carolinabomb
Jul 26, 2015 08:40 AM
