250R Crank
Originally posted by: dragracer789
Shouldn't all the year cranks be the same? I think all thats diffrent is the connecting rod and piston....
#15
Ok, so now here are your options. You can put any year crank in that motor but the last time I checked prices, an '86 crank was considerably more money than the 87-89 year cranks. So it might be best to buy a long rod crank and if you use an '86 piston you will have to use a spacer plate and possibly modify your head stay if you are using one. Or you can buy the '87-89 style piston and not have to worry about the spacer plate.
