Rubicon fan
Old Aug 28, 2000 | 01:17 PM
RubiRider's Avatar
I have a green Rubicon with about 45 miles and I love it. No problems so far, but I have a question about the fan. Almost every time I kill the motor, the fan will engage within about 5 seconds if the key is left on. It will run for about a minute. It also comes on when riding slow trails. Is this normal? Should I let the fan run until it stops and then turn the key off?
Thanks
Old Aug 28, 2000 | 02:35 PM
TxDoc2's Avatar
Mine does that, also. There must be a computer-controlled temp sensor that tells the fan to run for a pre-set time. Quite a bit of air being moved by the fan.
Old Aug 28, 2000 | 02:50 PM
TEXMud's Avatar
It is coming on when riding slow on the trails because there is not much air flow to cool it off. The fan will force the airflow. As far as it coming on after you kill the engine, it is acting like a car trying to cool the engine. As with TxDoc2, mine does this also.
Old Aug 28, 2000 | 04:54 PM
RubiRider's Avatar
Thanks, I just wanted to make sure it wasn't running too hot. It must have a low engagement temp. I ride with a 2001 Kodiak and his rarely comes on. I appreciate the info.
Old Aug 28, 2000 | 05:11 PM
TEXMud's Avatar
Its been over 100 here for months so mine is almost always on.
Old Aug 28, 2000 | 05:26 PM
xepathfinder's Avatar
that is liquid cooling doing its job.
Old Aug 28, 2000 | 11:51 PM
rooster's Avatar
Same here, the fan goes on quite a bit. It seems to come on at a lower temp than other liquid cooled machines, which to me is a good thing. If the fan is on when I turn the machine off, and I know I'm gonna ride it again soon, I usually let it run its course. If I'm not gonna ride it, it doesn't pay to let it run.
Old Aug 29, 2000 | 09:03 AM
atving's Avatar
You guys are just not use to a liquid cooled machine, don't you love the way it keeps the engine cool. Don't start worrying till the fan doesn't start coming on...this is regular for a water cooled machine...
shimanok2
Jan 29, 2016 07:37 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
colt1126
Aug 18, 2015 10:38 PM
