Brake problem
Old Oct 4, 2004 | 12:31 AM
riderman's Avatar
Default Brake problem
After applying the rear brake and letting off of it, it stays hold and makes a nice, really loud, squeek, then it lets go. It does not do it if you loosen the adjusting nuts, but them it wont hardly stop. Took the drum off and the brakes are still good. I also cleaned them while I had the drum off and it still does it. What is the problem? It is a Rancher
Old Oct 4, 2004 | 01:35 PM
riderman's Avatar
Can anybody help me?
Old Oct 4, 2004 | 02:34 PM
hondabuster's Avatar
Is the return spring still hooked up? Its the one on the outside of the drum, on the arm. The moving surfaces of the brake cam need some lube on them, just a dab of grease should do it. Thats the rotating piece, that separates the shoes.
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Chuck188
Jul 17, 2015 02:45 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
