Thinking about 426cc piston
Old Oct 8, 2004 | 10:49 AM
Ernie660R's Avatar
Default Thinking about 426cc piston
No its a sleeve, no replating is required!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 8, 2004 | 02:20 PM
cals400ex's Avatar
i am running at 11:1 ross 426. i am running a thin cosmetic head gasket and no base gasket. i have hondabond sealant on the base though. this will raise the compression a bit and give a better flame travel accross the piston. i also had my piston coated for better heat dissipation. also, i have the light pin that holds the piston in place. it definatly weighs less than a normal pin ross gives with their pistons. i am running a sparks x-6 exhaust. i had this thermally coated also. i am running a TC mx grind cam, heavy duty timing chain, FCR 40mm carb, GT Thunder rev box (increases rev limit and also advances timing 6 degrees). i also have a sparks clutch, uni air filter, modded air box lid (only use it sometimes). i currently run stock gearing. that is what i found to be best for my style of riding.
the 400ex does not have a plated cylinder. the Z's and KFX's do though.
Old Oct 8, 2004 | 05:37 PM
TNTQuadJunkies's Avatar
I have a Ross 11:1 426ex and have had nothing but GREAT results!!! Also have the GT Thunder Rev Box, open Air Box, porting, Aftermarket Valve springs,Hot Cam Stage II. I debated over the 440 kit, but after having mine now since Jan. I feel I made the right decision. [img]i/expressions/face-icon-small-wink.gif[/img]
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
southbayman
Jul 24, 2015 09:30 AM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
