Sprocket Question
Old Oct 14, 2004 | 09:35 PM
NCguy84's Avatar
Default Sprocket Question
Okay, i have a 400ex and i am looking for more bottom, i hardly ever ride where i can get wide open, and i am thinking about getting a 14 tooth front sprocket. I have also thought about getting smaller diameter tires (18x10.5x9 klaws) but my tires are still in good shape. Also if i get the 14 tooth sprocket will i have any probs with my chain? I have heard that i might have to take a link out. My bike is only about 3 months old and the chain is in really good shape, has not stretched much yet so hopefully i would not have to do this. I just want yall opinions on sprocket deal. Also would it be better for me to keep the stock gearing and just go with a smaller rear tire? Thanks for the info ahead of time.
Old Oct 14, 2004 | 11:24 PM
moto93's Avatar
Go with the 14, you won't have a problem with the chain.
Old Oct 15, 2004 | 07:33 PM
Hondanutcase's Avatar
I wouldn't worry about the tires. Changing to a 14 tooth front sprocket is a big difference. You will loss top end but the sprocket change does help a lot if you want low and mid range power.
Old Oct 15, 2004 | 08:29 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I ran 22" Holeshot XCT's for a while, and figured I would gear down to make up for the bigger tires. So, I put on a 14T sprocket. It was fun for "play riding", but useless out on the trail. The slightest blip of the throtle had the front end reaching for the sky. If you got carried away and powered out of a turn, the front would come up and you would lose steering. I would go a tooth bigger in the rear. Any more than that is to much.
Is you bike piped, or your motor modded in any way? If not, you may be down on power because of that??? The EX is famous for its low end grunt. Can't say what is wrong with yours.
Old Oct 16, 2004 | 12:17 AM
BURKEDADDY's Avatar
Textgear calculator
check this out for tire and gear combos
Old Oct 16, 2004 | 01:30 AM
mucky's Avatar
1 tooth smaller on the front will really pep up the bottom end
I wouldn't go smaller tires changing gears is lots less $$$ than tires
Old Oct 16, 2004 | 01:07 PM
NCguy84's Avatar
Thanks for the info guys. I ordered my sprocket friday. Hope its what im lookin for. Oh yeah, and my bike is piped (pro circuit t-4) and k&n air filter with outerwear and airbox lid off with a 155 main jet. So my bike is not down on power i just want more bottom. Thanks
Old Oct 16, 2004 | 01:45 PM
Red Rider
Let us know how it works out. My bet is that you will become the wheelie king.
Old Oct 20, 2004 | 06:52 PM
NCguy84's Avatar
Okay, i put the sprocket in today, and i noticed alot moer power down bottom. But on the down side it seems that i have lots quite a bit of top end speed. I knew that i was going to lose some but i think i may have lost a bit to much. Oh well, i will really see if i like it when i go ridding this weekend. And if not that i will put the old one back on. But as far as acceleration the 14 tooth does wounders... and ALOT eaiser to get the front end light [img]i/expressions/face-icon-small-happy.gif[/img]
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
wendal
Sep 15, 2015 01:50 PM
