400ex runs like SHlT
its nice to hear u got it running good. you'll probably have to go up a lil bit on the main again once u get the R4, but try riding the bike with the 155 main before u re-jet for the R4. that way u'll get an idea on how much more u need to go up on the main, if ne at all.
the 155 dynojet is actually too big. it should run much better than with the 165 in though. a stock keihin 148 mainjet is equivalent to a 142 DJ if i remember correctly. so around a 148 DJ should be more than enough, but the 155 would work if you don't have anything else. yes, going with the smaller mainjet will increase your top end.
i didn't realize that dynojet uses a dif. sizing system, i figured the only difference would be in the design of the stamp on the jet. don't got too small on the main, it may increase top speed but if u start running lean (your headpipe will get really hot all the time) you can really mess stuff up.
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
