winter storage?
Old Oct 31, 2004 | 12:19 AM
Jordanw's Avatar
Default winter storage?
whut all should i do to get my atv redy to put away for winter, i heard about spraying it with some sort of anti rust stuff.... whut else do u do??
Old Oct 31, 2004 | 12:33 AM
hondabuster's Avatar
At the minimum..drain the gas, and use it in something else, because next spring itll be bad. Drain the float bowl dry, this will keep the carb from plugging up. Either pull the battery inside, or put it on a battery tender. If its only gonna sit 6 months, this should be good enough.
Old Oct 31, 2004 | 01:26 AM
iceracer65's Avatar
another thing you could do is to roll the motor over untill it is on the compression stroke. this will seal the cylinder from alot of moisture that can leak in thru the intake/exhaust valves.
Old Oct 31, 2004 | 02:58 AM
Polaris500HO4x4's Avatar
take a teaspoon or just a little less and put that in your piston and turn over your engine without the plug.
Old Oct 31, 2004 | 02:59 AM
Greco's Avatar
why store it for the winter when you can ride it all year round????
Old Oct 31, 2004 | 11:24 AM
Jordanw's Avatar
thanx a lot for your help, i wan't to store it because i don't have aney time to ride it in the winter and i think it would be just eseor to store it and not worrie about it untill spring ten i can get back out there[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 31, 2004 | 08:00 PM
Mutha's Avatar
Drain the oil, and change the oil filter before you put it away also.
This should keep the motor free of acids and contaminants which is good for neither the internals, nor the seals.
Old Nov 5, 2004 | 01:10 AM
Daranello75's Avatar
No need to drain your tank, fill your tank up, to prevent condensation in your tank. Use Staybil or other fuel stabilizer in your last tank of fuel prevents varnish buildup and also has an anti-bacterial/fungal agent to prevent stuff from growing in the carbs and fuel left in your tank. If you don't drain the tank, make sure to store full of fresh gas with additional stabilizer to prevent condensation.
Old Nov 5, 2004 | 04:50 AM
Mutha's Avatar
Antibacterial/antifungal agent??
I've never known any bacteria, or fungus to be able to live in gas??
Is this after it has sat for over a year or????
I'm confused![img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 5, 2004 | 09:12 AM
bullhoggrande's Avatar
It is probably for along the walls of the inside of your tank. I always put my quad on a couple of 10x2's to keep the tires off the cold concrete, as that tends to make your tires crack and dry out.
