250R carb spring
Old Sep 2, 2000 | 12:10 PM
ridzhard's Avatar
I just put a twist throttle on my 88 250R and the carburator has a very light return spring. This causes the twist throttle to feel to light for me, I like a little more resistance. Can anybody tell me if there is a heavier spring for the carb? Thanks.
Old Sep 2, 2000 | 03:01 PM
FireBug's Avatar
You should turn the lock nut on the top of th carb and then turn the adjusting screw and see if that helps.
Old Sep 2, 2000 | 03:02 PM
FireBug's Avatar
Old Sep 2, 2000 | 06:58 PM
ridzhard's Avatar
There is no such set-up on the 88 carb. If there were, it would be to adjust free play in the cable. I do think I found my own answer however. I was adjusting the needles on my Banshee for the drop in tempature we are/will be getting and when I looked at the Banshee spring, a light went off in my head. It is bigger than the Honda spring. I have one on order, if it works, I'll let you know.
ghost civic
Jan 15, 2020 07:43 AM
CRamshaw777
Jul 18, 2015 05:46 PM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
