cr250 head gasket?
Old Nov 1, 2004 | 10:31 PM
yamahatheonlyway's Avatar
Default cr250 head gasket?
i have heard of ppl puttin a cr250 head gasket into their 250r's. My 250r is out in the garage gettin a makeover right know and im wonderin what the bennefits... if any are, to puttin in a cr250 head gasket.... and if they're are any other little tricks u guys do out there to get a little more boost out of ur 250's
Old Nov 2, 2004 | 02:52 AM
trapperb1's Avatar
A CR headgasket is much thinner than a stock TRX gasket. This will increase your compression and give you more power. It's cheap,reasy to get power. If the CR gasket is too thin for you, you can also try the ATC gasket; it's thickness is in-between the CR and TRX.
Old Nov 2, 2004 | 08:10 PM
bansheeesmoker's Avatar
cometic gaskets for a trx are the same, or run a 91 cr250 head gasket. those are your best choices.
Old Nov 3, 2004 | 02:32 AM
HughJazz's Avatar
If you put 2 base gaskets on under the cylinder it will change you port timing and increase your power. You can take apart the head gasket and take the middle piece out to raise compression too
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
