Heat Tape on the oil tank
Old Sep 3, 2000 | 11:47 AM
Trx-400ex's Avatar
What would happen if you put that fiber glass heat tape on the side of the oild tank that faces the headers? Would the direct a lot of the heat off the oil tank....hence keeping a better cooled engine?
Old Sep 3, 2000 | 01:46 PM
86atc250r's Avatar
Surely it couldn't hurt, personally I don't like the headers being that close to the oil tank either....
Old Sep 3, 2000 | 05:56 PM
Trx-400ex's Avatar
Hey Gabe its Ethan...Remember me from Radical robs? Number 97 parked right by you....Well anyway was riding yesterday to make sure my Pipe wasnt going to burn a hole in my new white plastic and Had to do a bit rewiring due to removing the kill switch and notice how hot the oil tank was...I wonder if it would help or just be a waste of money or would it keep the heat in the oil tank? And have a negative affect?
Old Sep 3, 2000 | 09:08 PM
HRC4EVER's Avatar
CONTACT HIGH LIFTER OR GO TO AN AUTOMOTIVE SPEED SHOP AND GET SOME HEADER WRAP. IT CUTS DOWN HEAT OFF THE PIPE BY 70 PERCENT AND INCREASES HEAT IN THE PIPE WHICH FLOWS BETTER AND ADDS HP.2-5 PERCENT INCREASE I'VE HEARD.I DID IT, IT LOOKS COOL(USE HIGH HEAT COATING),RUNS COOLER,BETTER POWER AND STAYS MORE CONSISTANT.IT WORKS!
Old Sep 4, 2000 | 01:14 AM
86atc250r's Avatar
Yep, I remember, I didn't even notice in your profile it said you were from Nixa....
Hope everything's going well....
Like HRC said, the header wrap is probably a good idea, I think some reflective tape like you mention wouldn't hurt either. I've been meaning to get one of those infrared temperature measuring devices and do some experimenting, just haven't gotten around to it yet.
Some of the guys here are running a 3qt Pingry<sp?> tank that has some cooling holes in it, maybe Rob (TRX440) will reply here. I have some pics of his if you are interested. e-mail me if you want to see....
Jeff Roper
Feb 1, 2022 11:48 AM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
Sw00p
Sep 24, 2015 02:50 PM
